    May 2005
    California
    I prefer have an ISO image instead of files or burning to a dvd.
    Which is the best tools for converting the video files to an ISO image so that I may use it with Daemon tools?
    Many thanks!
    Yancey
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    The "classic" version of ImgTools is the best program for converting DVD files (VOB, IFO, BUP etc.) to an ISO IMAGE file.
    For burning that ISO IMAGE file I prefer to use DVD Decrypter. You might also want to try ImgBurn which is a new program for just burning by the maker(s) of DVD Decrypter (since DVD Decrypter is no longer being updated).
    - John "FulciLives" Coleman
    May 2005
    California
    Many thanks,
    I'll give it a try!
    Yancey
