hi, I have a problem with the audio-converting tool TOOLAME.
it won't run, even into ms-dos mode. I try every thing. help me to run it, or prehaps an other programm???
THANX, FRIENDS.
GO ON
Unzip toolame.zip to any directory.
Start TMPGEnc, select option-> environmental setting->external tool. Check Layer-2 and browse for toolame.exe.
Hit OK, done. -
Do you have an AMD processor? I do, and a while ago there was a toolame version that didn't work on AMD processors. Running that version showed an error.
I downloaded a newer version and probs were gone.
My TV doesn't run either .DTS and .AC3 file from .MKV movie
By galodoido12 in forum AudioReplies: 2Last Post: 3rd Feb 2012, 23:29 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
Will my pc run W7 32bit?
By neworldman in forum ComputerReplies: 6Last Post: 20th Oct 2010, 14:42 -
where is RUN on Windows 7?
By jyeh74 in forum ComputerReplies: 7Last Post: 17th Dec 2009, 18:00 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58
