I noticed this Loading of files OR somthing that has brought up MS Office Try to "Install somthing", what the hell is it? There have been many sites in the last week doing this.
Whats going on?
Its a bug we've had it on work machines. Not sure of this fix though.
Should work as long as you have flash installed. You and IE user by chance? -
Man, I tried to find the solution to that problem. I KNOW there is one because we had it before but for the life of me can't find the info. I'll ask around work.
You might try this http://annoyances.org/exec/show/article08-103
and a further link from the same article http://support.microsoft.com/default.aspx?scid=kb;EN-US;q265194Read my blog here.
There is an Office update that is supposed to fix this. It's actually a vulnerability IIRC. Remember that Windows update doesn't have this, Office update does. And in order to use Office update you need your install CD or some damn thing. All I know is I couldn't update at work because we don't have the individual installers, everything is imaged.
FB-DIMM are the real cause of global warming -
******* A thats it. thanks. My search skills failed on that one.Originally Posted by guns1inger
Another way (for future reference) is to get a hold of the Microsoft Installer Clean-up Utility. We had the same issue when we deployed Symantec AV 9 Corporate Edition too quickly.
If you go to Office Update and you are asked for your CD when installing, look for what's called the full-file or network admin install (for some reason they're listed differently sometimes). They're usually much bigger, since they include the files that Office is looking for from the CD. It takes longer to download, but you shouldn't need the CD. I have seen before Windows XP SP3 asking for the CD with the full-file, but I think that it only affected people with a custom application we had.
What is windows installer for?
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2010, 13:51 -
windows installer?
By marcusden69 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 15th Feb 2009, 07:36 -
Mass conversion of Office 2003 files to Office 2007?
By Xylob the Destroyer in forum ComputerReplies: 8Last Post: 17th Jun 2008, 00:06 -
avidemux installer problem
By jwfc in forum Newbie / General discussionsReplies: 6Last Post: 5th Jul 2007, 08:48 -
How to stop an installer from running?
By Duchess in forum ComputerReplies: 3Last Post: 3rd Jul 2007, 10:21
