My nephew had our old family movies made into a DVD. I asked him to send a copy of the DVD but he don't have a DVD burner. He put all these files on his website for me and I downloaded all of them. Now I don't know what to do with them or how to do it. I have a DVD burner but am unsure what software and/or procedure to take.
All the files that he gave me look similar in name:
Video_TS, VTS_01_0, VTS_01_1, and they go all the way to VTS_05_1.
Is there a way that I can restore these files to a DVD so that I have a copy of my familie's home movies on DVD to keep forever?
Thanks!
BOB C.
http://members.dodo.net.au/~jimmalenko/NeroExpress.htm
There's more guides for other softwares in the guides section, under "How to burn an already authored VIDEO_TS folder".If in doubt, Google it. -
Another option is to use the following two programs:
1.) ImgTools (make sure it is the classic version that you are using)
2.) ImgBurn
The first program will create a single ISO IMAGE file from the various DVD files you have now.
Basically create DIR with another DIR in it called VIDEO_TS and put the DVD files in the VIDEO_TS folder.
So you have:
TOP FOLDER (call it MOVIE or whatever)
- VIDEO_TS folder (in the MOVIE folder)
- All the DVD files (in the VIDEO_TS folder)
Using ImgTools you would just select the TOP FOLDER (MOVIE as I called it in my example) and it will output a single ISO IMAGE file. Make sure you have enough HDD space. If the DVD files equal say 4.2GB then the ISO IMAGE file will be 4.2GB etc.
Now use ImgBurn to BURN that ISO IMAGE file to a DVD in your DVD Burner.
Both of these programs are 100% free to use and both work great!
Burning a VIDEO_TS folder to disc makes it a playable DVD right ?
By Bansaw in forum Authoring (DVD)Replies: 25Last Post: 1st Mar 2015, 16:34 -
VOB2MPG - VIDEO_TS AND VTS_01_0 aspect ratio problem
By Joey9 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 21st May 2010, 08:28 -
Burning DVD with VIDEO_TS Folder
By bguguen in forum MacReplies: 7Last Post: 28th Jul 2009, 01:10 -
problem with menus when burning VIDEO_TS files to DVD
By samd292 in forum MacReplies: 3Last Post: 24th Jun 2008, 09:49 -
FAVC - Missing VIDEO_TS.bup, VTS_01_0, VTS_01_0.BUP, VIDEO_TS (.vob)
By Brent.M in forum Newbie / General discussionsReplies: 14Last Post: 8th Feb 2008, 08:47
