i'm so sorry if there had already been a topic about this, but i can't seem to find or see it anywhere.
is there a program use to cut scenes from a video? like jsut to cut a certain scene.. because i want to wrap up some part together.. but i don't know how.. thanks..
is there also a software to put all the scenes together withough pausing per scene like per 1/2 seconds cuz on Windows Movie Maker, it does that.. and it's not really that good. thanks.. the software is free though right? thanks in advance!!(:
I think I've heard of programs like this...let me think...Oh yeah Video Editors! :P
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Assuming MPEG video, as in a DVD.....You can do that with a MPEG video editor. Might take some experimenting to get the effect you want.
If you look in 'Tools' to the left <<<, you can find two main types, Basic and Advanced. The Advanced ones are pricey, the basic ones will do most of what you want. Transitions and effects are mostly with the more expensive ones. Most versions of either have a limited trial version, so you can 'test drive' them.
If you look at the page for the individual editors, you should see some guides near the bottom that may give you a better idea of what they can do.
You can still do some professional editing even with the inexpensive editors, just takes more work and more studying.
What program can I use to cut segments from a mp4 video?
By alc112 in forum EditingReplies: 9Last Post: 1st Jul 2011, 19:31 -
SW for cut / delete scenes
By Luoslav in forum EditingReplies: 2Last Post: 16th Oct 2010, 06:02 -
What program to cut out unwanted sections of DV-AVI for archive
By piperpilot12w in forum EditingReplies: 6Last Post: 30th Aug 2010, 01:52 -
What is the best program to split/cut/edit HD videos ??
By ZaYoOoD in forum EditingReplies: 7Last Post: 7th Jun 2008, 16:55 -
I'm wanting to cut some scenes and add some fade-ins to a DVD video.
By Ryan J in forum MacReplies: 4Last Post: 17th Apr 2008, 09:42
