Can you tell me any free program that can add the fade in and out into the video please?
I'm using Ulead Video Studio, but only for 30 days (trial)![]()
There's a whole number of applications in the "Video Editors (Advanced)" category of the "Tools" section.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
You could use AVISynth and then frameserve to an encoder:
https://www.videohelp.com/forum/userguides/99389.php#fadeIf in doubt, Google it. -
In Ulead Video Studio, look under effects F/XOriginally Posted by voxiRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
You can use Wax2. It easily lets adjust the opacity of the clip and much, much more.
You can probably do it with Virtualdub using the logo filter and a black (or whatever color you like) BMP, but I never tried it.
Never used Windows Movie Maker, but I'm sure you can use a Crossfade transition between your clip and a black BMP.I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
production library>transitions>fade to black FX
the cross fade FX is there, too.
You can always use the filter's and turn down the brightness and contrast, too. -
Wax is a fantastic tool. You could also use AviSynth, though it's less intuitive, but AviSynth gives you more control over the effects. Ulead Media Studio Pro is a great program and worth the money, if you do decide to buy it. I find it nearly as powerful as Premiere but much easier to use.
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 12:45 -
Fade in Fade Out CD Music Software
By mn072065 in forum ComputerReplies: 0Last Post: 6th May 2008, 08:23 -
how can I add "Fade in / Fade out" effect in my video clips
By mb508 in forum EditingReplies: 5Last Post: 9th Jul 2007, 16:02 -
fade in/fade out with smart rendering
By bmf in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Jun 2007, 13:33 -
Fade-in\Fade-out filter, VirtualDub MOD
By GangstaRap in forum Video ConversionReplies: 3Last Post: 21st May 2007, 20:58
