Was having some trouble with my burner where a lot of the disks were turning out choppy and was told it was a media problem and to get Taiyo yuden disks and the problem would go away. So I got them today and tried to copy a disk using dvd shrink and bero and got this error.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 5:35:34 PM
Nero API version: 6.6.0.16
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 16b
Recorder: <SONY DVD+-RW DW-D56A> Version: PDS7 - HA 1 TA 0 - 6.6.0.16
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : FUJITSU MHT2040AH atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SONY DVD+-RW DW-D56A atapi Port 1 ID 0 DMA: Off
=== CDRom-Device-Map ===
SONY DVD+-RW DW-D56A D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523644kB)
Free physical memory: 97MB (100144kB)
Memory in use : 80 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
7.11.2005
NeroAPI
3:45:52 PM #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
3:45:52 PM #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
3:45:52 PM #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
3:45:52 PM #4 Text 0 File Reader.cpp, Line 127
Reader running
3:45:52 PM #5 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
3:45:52 PM #6 Text 0 File Writer.cpp, Line 122
Writer SONY DVD+-RW DW-D56A running
3:45:52 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
3:45:52 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3309
3:45:52 PM #9 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
4:04:28 PM #10 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2286111 (508:01.36, 4465MB)
4:04:28 PM #11 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO
4:04:28 PM #12 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: SONY DVD+-RW DW-D56A, Media type: DVD-R
Disc Manufacturer: TYG02 -
Disc Application Code: 64, Disc Physical Code: 193
4:04:28 PM #13 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: unknown. Medium required by compilation: DVD+R/RW, DVD-R/RW, DVD+R DL.)
4:04:28 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2286112 (2286112) = #2286112/508:1.37
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286112 blocks [SONY DVD+-RW DW-D56A]
4:04:28 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [SONY DVD+-RW DW-D56A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681957376, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2286112 | lead-out | 1 | 0x41 | 0x00
4:04:29 PM #16 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
4:04:29 PM #17 Text 0 File Burncd.cpp, Line 4120
Cache writing successful.
4:04:29 PM #18 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
4:04:29 PM #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 6x (8,310 KB/s)
4:04:29 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
4:04:29 PM #21 Text 0 File DVDR.cpp, Line 2379
Recording mode: Sequential Recording Mode
4:04:30 PM #22 Text 0 File Mmc.cpp, Line 21708
Set BUFE: Power-Burn -> ON
4:04:30 PM #23 Text 0 File DVDR.cpp, Line 2534
Start write address at LBA 0
DVD high compatibility mode: Yes
4:04:30 PM #24 Text 0 File Cdrdrv.cpp, Line 8862
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
4:06:46 PM #25 Text 0 File Cdrdrv.cpp, Line 1286
16:06:46.515 - SONY DVD+-RW DW-D56A\H1 T0 : Queue again later
4:07:16 PM #26 SCSI -1135 File Cdrdrv.cpp, Line 1434
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x015E0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x0D 0x40 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
4:07:16 PM #27 CDR -1135 File Writer.cpp, Line 311
Write error
4:07:16 PM #28 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
4:07:16 PM #29 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
4:07:16 PM #30 Text 0 File DVDR.cpp, Line 2774
EndDAO: Last written address was 3391
4:07:17 PM #31 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 6x (8,310 KB/s)
4:07:17 PM #32 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
4:07:17 PM #33 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/17/2001 1:07:32 PM
File 'Drivers\PXHELP20.SYS': Ver=2.03.27a, size=20576 bytes, created 1/26/2005 1:03:00 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Can anyone make sense of this? Also, what is DMA someone said my DMA is off. If that is the case how do i turn it on.
Do a search on this forum for DMA. There are a number of detailed threads on this.
I figured out the DMA problem and now both my primary and secondary IDE's are working in DMA. So I tried burning the disk that gave me that error and it worked. but when i plated it about 5 minutes into it it froze and then played the last 30 seconds or so again, then froze in the same spot again and do on. Ran a disk quality test with cd-dvd speed and here is what i got.
What are you playing it on? Could be your standalone. Try burning with something else like DVD Decrypter.
Playing it on a Sony dvd player. It's pretty old. I don't think it is the player though because when i scanned the disk usingcd-dvd speed it showed a lot of damaged area on the disk. Downloaded DVD Decrypter express and it looks like all it does is copy the disk to your hard drive. What do I do from there?
Older Sony's are very problamatic with recordable DVD media. IF you have access to another player, try your disc on it.
[ASK] Error Burn BD with Imgburn
By m1x in forum Blu-ray RippingReplies: 5Last Post: 30th Jun 2010, 11:25 -
Error when trying to burn
By arose1179 in forum Newbie / General discussionsReplies: 6Last Post: 16th Oct 2008, 16:12 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 20:58 -
I/O Error in IMG Burn - Help!
By msdker in forum Newbie / General discussionsReplies: 7Last Post: 21st May 2008, 23:11 -
Cannot burn DVDs, error message
By mataharimata in forum Authoring (DVD)Replies: 27Last Post: 22nd Mar 2008, 06:59
