    Oct 2005
    Nottingham
    I have created several dvd's from mpegs, but when I play on most DVD players and my ps2 I get a crackly/jumpy audio. The video is fine but the audio sounds like it's playing on a bad vinyl album! Eventually the audio is out of sync by seconds.
    However if I play them on the cheapest Pacific player that I have (bought for £40 from ASDA) they are perfect. I'm quite new to this whole DVD business and thought I was doing alright! I use TMPGEnc DVD Author 1.6 to author them and Mpeg Video wizard to join any clips. I had used ifoedit to author them but then read all of your forums saying not to use it and thought that would solve the problem.
    I have trawled through hundreds of posts but can't seem to answer my question.
    Thanks in advance
  2. What type of file is your audio in? .wav, .mp3 etc..
    Oct 2005
    Nottingham
    I normally split the files into m2v and mpa. I only do this as it was the first way I did it and I've stuck to it!
