I'm pretty new to Vcd's and need some help. I tried 3 times last night playing vcds on my Apex-Ad1000 and all i get is a choppy picture and no sound. I am burning mpg's with Adaptec Easy Cd Creator 4. These mpg's play fine on my computer and have exellent sound. I Don't think there's anything wrong with my dvd player because it plays dvds and mp3 cds flawlessly. Am I burning the VCD wrong?
Results 1 to 9 of 9
There could be thousands of things you are doing wrong. Please explain in detail the steps you took to make your VCD's. Also let us know the hardware/software you are using.
If you are ripping from DVD's, try reading SEFY's Guide for newbies, else read the HOW-TO section on the left side of the screen. -
Here are the steps I took.
1. Downloaded Rat Race Cd1 from irc
2. Made rars into .bin file
3. Converted .bin file to mpg using vcdgear v3.05
4. At this point it sound and video work fine using WMP 7.1
5. Burn mpg onto disc using Apaptec EZ Cd creator 4.
6. Put it into dvd player and really choppy video and no sound.
Is there stuff i have to do inbetween or am I doing it right? -
Have you tried burning the MPG with a diffrent program ? like maybe Nero ? VCDeasy ? TSCV ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
If you downloaded a CUE/BIN disc image, then why don't you just try burning that (rather than converting to MPEG).
http://www.geocities.com/medinotes/vcd/burning_cuebin_images.html
Regards.
Michael Tam
w: Morsels of Evidence -
I have the same problem ,is this because used deamon tools to make a virtual drive and then treated this drive as a cd reader drive and burned a cd using adaptec cd copier
Riad: No, I've done that many times, it shouldn't give you any problems.
I was stupid not to recognize this in the first place, follow vitualis's method. Go to the website he posted, it's pretty self explanatory. I, myself would probably follow the fireburner method.
_________________
"I am not a cheerleader for your idealogy."-Bill O'Reilly
<font size=-1>[ This Message was edited by: MustangGT on 2001-12-25 10:06:33 ]</font> -
Thanks for all ur help but i figured it out. I upgraded to Roxio EZ 5 PLatinum and use the Video CD Burner. Works FLawlessly.
So you wasted over 100 more mb and installed a newer interface for the same program, just to do what you could have done with any of the free and smaller programs ?
Best Regards,
Sefy Levy,
Virtualdub - What did I do wrong?
By tigerb in forum Newbie / General discussionsReplies: 7Last Post: 15th Oct 2008, 11:42 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 09:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 18:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
