After discussing various encoders here for a few days, I've decided to go back and give CCE (which I never liked) another try. I'm having an inexplicable problem: though I set the output for "DVD compliant", I always wind up with an mpg that has the same resolution as my original divx. My dvd authoring program will say, for example, "640 x 480 cannot be used to author DVD". When I go back and check my divx file, sure enough, it's 640 x 480. Why isn't CCE changing it if I specify DVD compliance? What am I missing here? Thanks for any help.
I've looked through the guides and haven't found a reference to this particular problem.
Results 1 to 19 of 19
Well, actually...
When I set to "DVD compliant", it DOES set the resize options to 720 x 480. But the mpg still comes out with whatever resolution the divx had. And I have read the manual, which doesn't address this problem at all. -
Learn to frame serve. You have basically three options.
Virtualdub ( or variant). Easy to use, visual feedback.
Avisynth. Scripted, non-visual, more complex, generally about 3 times faster than virtualdub on more complicated filters.
Debugmode FS. Requires either Vegas or Premiere. Allows you to frameserve from the timeline to the encoder of your choice.
CCE does not have all the bells and whistles of something like tmpgenc, so you really need to do all your resizing and filtering before you get to it. On the plus side, it is of equal or better quality, in a bout a third the encoding time.Read my blog here.
Learn to use AviSynth. It actually is pretty easy to use.
For AVI clips you can try using FitCD which will generate an AviSynth script for you ... just make sure you install AviSynth.
CCE is great but mostly worthless without using AviSynth.
Also it is a bad idea to use that DVD Compliant option in CCE.
Originally Posted by FulciLives
Originally Posted by skeg64ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
If you're feeding a correct stream to CCE, then this option doesn't need to be checked..
It's sort of like a safeguard against streams that aren't DVD compliant..
It's been a long time since i've read the .PDF of CCE, but many of my stuttering problems went away after unchecking "Make DVD Compliant".. -
Originally Posted by manono
I've always used this parameter, but I don't really know if it is doing me any good. But then, with a proper script to feed CCE (I mostly frameserve to it), checking this box may not be necessary.ICBM target coordinates:
Originally Posted by hrlslcbr
A look at the user guide always helps. Damn but I hate PDF. Can't cut and paste. I'm using CCE 2.70:
Outputs DVD compatible stream. If the resolution (framesize and framerate) does not match with DVD standard, it will be automatically converted...In DVD Mode, when you select 2-pass VBR, 9,800 kbps is always written as maximum bitrate in the sequence header of output MPEG files, whatever value you may set...Note that actual bitrate does not exceed your maximum bitrate setting even if 9,800 kbps is written in the sequence header. -
"If DVD complient is selected, instantaneous bitrate in GOP units is controlled to be a maximum of 9.8 Mbps. During VBR operation, 9.8 Mbps is always written to the sequence header regardless the specified maximum bitrate. 9.8 Mbps is the maximum bitrate allowed under the DVD standard. 9.8 Mbps is used here because in the case of the VBV model in VBR, bit allocation planning by the encoder becomes more flexible as the maximum bitrate becomes higher, therefore higher image quality can be achieved."
Never tried the "resize" capabilities, but the 2.50 manual says that it is "matted" to the proper resolution.ICBM target coordinates:
Difficult to explain (sorta) computer problem
By Heywould3 in forum ComputerReplies: 10Last Post: 9th Nov 2011, 10:48 -
Can somebody explain the problem with this dv footage.
By Aarzoo in forum RestorationReplies: 8Last Post: 18th Jul 2008, 09:28 -
cce video bitrate problem
By DSLGuy in forum Video ConversionReplies: 11Last Post: 16th Feb 2008, 12:53 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
can someone explain?
By icucmerc in forum Video ConversionReplies: 2Last Post: 4th Aug 2007, 10:57
