I am a newbie and not sure if this is the right forum. I Decrpt DVD with DVDDecrypter and then burn using DVDShrink/Nero.
Some times, I cannot rip the few VOB files due to media errors or scratches. In this case I have all VOB but the last VOB is incomplete. It has end of the movie but not last 10 seconds. I am fine with that. I can play the VOB using media player and watch. Offcourse I can not watch last 10 seconds which are nothing but texts at the end.
When I try to encode using DVDshrink it gives me error. Is there any way to reduce (reencode) and burn the movie with incomplete VOB? Please let me know. The entire Video_TS folder is more than 5 GB it must be reduced by encoding.
Thanks,![]()
This should work. As you are using DVD Shrink i suggest when you go to reauthor and drag main movie only over, just right click and do a 'start and stop' with 'stop' being before the 'bad' 10 seconds. Now back up.
open the folder on ur hdd where you saved the files ... identify the vobs for the main movie and discard everything else then use ifoedit to create new ifo's (open ifoedit and click create new ifos from the bottom toolbar ... load the first vob and make sure that destination same as source is checked the click ok) it will work ... i've done it myself lots of times where i have had a bad read at the end of a disk (usually caursed by kids dropping the disk and chipping the edges)
Thanks Captain. I will try this tonight and provide the feedback. Will this change the chapter location/selection? I never used the ifoedit before, but give a shot today.
how to author incomplete VOB
By Banleno007 in forum Newbie / General discussionsReplies: 3Last Post: 15th Feb 2012, 20:44 -
How to author & burn a DVD from VOB trailers/files
By Baldrick in forum User guidesReplies: 62Last Post: 30th Sep 2011, 06:39 -
how do I fix an incomplete vob download?
By NotHarry in forum Newbie / General discussionsReplies: 3Last Post: 30th Nov 2008, 12:43 -
re-author a .vob
By forare in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2008, 02:20 -
re-author minidvd withe one missing .vob
By Gondor in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 04:02
