Is there any way if increasing the number of simultaneous downloads that one can have at the same time in XP? (i.e. if I right click on a file and chose 'save target as....' I seem to be limited to four files at a time).
Regards,
Rob -
I'm pretty sure that's a server limitation, nothing to do with windows. 4 seems to be the standard, I've seen it where you can get only two connections at a time from some sites.
4 is the default in XP.
you can get various programs that let you change this (TweakIE for example) or you can change it in your registry (but I don't know where - I used a tweak program to change mine to 8"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Or use a download manager such as reGetOriginally Posted by Xylob the DestroyerThere are 10 kinds of people in this world. Those that understand binary...
Damn, I was kind of hoping for an easier fix to the problem (like changing IE settings) but if I have to start playing with the registry and even then be possibly faced with server limitations then maybe four is my max
Thanks for the help guys - knew I could count on you
Regards,
Rob -
I was did a little research on that, appears that you can but it's not very practical..... Essentially you would have to only limit the connections in a single directory where you wuld place all the files that you wanted to limit. The ones where I could only get two were probably ones where they had done this. More than 4 is possible.Originally Posted by rhegedus
Try using Firefox to download some of the files.
I've DL'ed 6 at a time using IE and Firefox. I've never gotten 4 with just IE through RoadRunner.
Help with simultaneous video outputs
By Rob #3 in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th May 2010, 22:53 -
VCD with 2 simultaneous languages in audio.
By v-sharp in forum AudioReplies: 9Last Post: 4th Feb 2010, 07:29 -
Multiple Simultaneous Video Capture - is it possible?
By PortoLad19 in forum Capturing and VCRReplies: 6Last Post: 31st Jan 2010, 09:10 -
Simultaneous video playout ?
By bertoa in forum MacReplies: 0Last Post: 9th Feb 2009, 09:06 -
Simultaneous video layering?
By SamZee in forum EditingReplies: 10Last Post: 15th Oct 2008, 08:13
