    Nov 2005
    Australia
    Hi Major,
    Ive been watching this forum not too long ago and have finally tried using ffmpegx 9t since i got my mac.
    Ive been wanting to convert my avi files to vcd using ffmpeg but so far i haven't had much luck at all. Im very new to ffmpegx and i dont know much how to make use of the bitrate calculator. Alost always i just use the presets for vcd. Here's what im doing and what im getting. I hope you can help me out.
    Encoding started on Mon Nov 7 22:18:09 EST 2005
    Input #0, avi, from '/Users/geoloic/Desktop/hard_word.avi.fixed.avi':
    Duration: 01:39:03.3, start: 0.000000, bitrate: 917 kb/s
    Stream #0.0: Video: msmpeg4, yuv420p, 448x192, 25.00 fps
    Stream #0.1: Audio: mp3, 48000 Hz, stereo, 32 kb/s
    Output #0, rawvideo, to '/Users/geoloic/Desktop/hard_word.avi.fixed.avi.ff.mpv':
    Stream #0.0: Video: mpeg1video, yuv420p, 448x256, 25.00 fps, q=2-20, 1288 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    [mpeg1video @ 0x4199e0]warning, clipping 1 dct coefficients to -255..255
    bench: utime=1788.620s
    video:934356kB audio:0kB global headers:0kB muxing overhead 0.000000%
    Input #0, wav, from '/Users/geoloic/Desktop/hard_word.avi.fixed.avi.ff.wav':
    Duration: 01:39:03.3, start: 0.000000, bitrate: 1536 kb/s
    Stream #0.0: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
    Output #0, mp2, to '/Users/geoloic/Desktop/hard_word.avi.fixed.avi.ff.mp2':
    Stream #0.0: Audio: mp2, 44100 Hz, stereo, 224 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    video:0kB audio:162514kB global headers:0kB muxing overhead 0.000000%
    **ERROR: [mplex] MUX STATUS: Frame data under-runs detected!
    Playing the img files outputed somehow shows video and audio encoded with the audio lagging behing.
    What should i do???
  2. Try to disable "Normalize audio" in the audio tab.
    Nov 2005
    Australia
    Thanks for the quick reply...however im still getting the same errors with the normalise audio off. Can you suggest another recourse.???
  4. Can you play your source file with Quicktime? If yes you may try to enable the option "Decode with Quicktime" in the Options tab.
