  1. Hi All,
    I'm creating a DVD with multiple VTS (due to different video ARs) and I'm struggling. I have a Photo slideshow MPEG, and two different videos. I have these branched off 3 menus The first 2 Menus are on VTS 1 and the third on VTS 2 but I cannot link them together. I've added bridges but its still not allowing me to link one menu to another? The bridge has the prongs one each side and one at the top, where do i draw the connections to?
    When I right click to select the link it only allows me to link to the other menu thats in the same VTS. I don't know what info you would need but can someone offer me some advice please?
  2. Why not create all the menus in VMG space? Then link to the correct VTS etc. .
    There is a reason why God gave us one mouth and two ears!!!
  3. Member pchan's Avatar
    Mar 2003
    Singapore
    VTS menu cannot link to VTS2 but VMG menu can.
    Example below shows VMG menu in VTS1 like to movie5 in VTS2.
  4. Serene Savage Shadowmistress's Avatar
    Mar 2004
    Controlled Chaos
    You need 2 bridges to get to and from your movie. Put all your menus in the same vts. From your menu select the button that would normally link to the second vts and link it to bridge one. Draw connection from bridge one to movie on vts2. Draw connection from movie on vts2 to bridge 2. Draw connection from bridge2 back to your main menu.
    All done. Some prongs on the bridges will remain empty.
  5. Thnks Very Much for the time you took to include screen captures, I used the VMG menu and its now working fine!
    Thank Again
