Hi all, hope you all had a safe bonfire night. any who I have a friend who has a problem with internet explorer, when he goes to certain sites he says "nothing appears" now i thought it could be a dead link! it also happens with blogs as well? has any one else had these kind of problems?
Xp sp2
thnx 8)
Hi,
There are different answers to why that would happen, maybe the internet connection is too slow and timing out before it is able to connect, maybe the web site is being worked on, it could also be a dead link, and so on. Sometimes if the pc does not have required software (java, shockwave, ...) the site is asking for, the site will not load either. I know sometimes the sites I go to will not load and nothing happens because the site needs java or it will not load at all.
I hope helps! -
Perhaps someone jacked up his firewall settings? Just throwing stuff out there.
Is it ALL sites?
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
Internet to tv
By moonlight in forum ComputerReplies: 5Last Post: 10th Feb 2008, 10:37 -
Kaspersky Internet Security 7.0 installation Conflicting with Internet Exp
By Krelmaneck in forum ComputerReplies: 2Last Post: 5th Oct 2007, 03:36 -
TV on Internet
By skybird in forum Newbie / General discussionsReplies: 7Last Post: 25th Sep 2007, 04:20 -
internet tv
By dewolf in forum DVB / IPTVReplies: 7Last Post: 21st Jun 2007, 13:49
