The following problem accurs when I use TMPGEng: I can't grab ANY of my movies. TMPGEng gives me this message: File D:\movies\rushhour2(DVD-RIP)cannot open, or unsupported.
I have already installed divX, so that can't be the problem.
The weird thing is, I had the same program installed about 6 months ago, and i worked perfect...
PLZ help :=)
The movies you are trying to GRAB, what format are they in? if they are ripped from DVD, they sould still be in VOB file format, you will need to frame-serve them first before TMPGENC can read them. Use DVD2AVI to frame-serve the ripped VOB files first, then TMPGENC will be able to read them.
If you found another way of doing this, I would like to know. -
probably has VBR audio, run the avi through VirtualDub with direct stream video copy and full audio processing mode to se a constant bit rate.
its when I select the browse button; under 'video' the message apears... :=((
Weird missa think
<font size=-1>[ This Message was edited by: jimmi_ploug on 2001-12-24 12:35:37 ]</font>
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
ffmpeg doesn't work at all
By Paulo2009 in forum ffmpegX general discussionReplies: 27Last Post: 5th Aug 2009, 00:55 -
Tmpgnc doesn't work
By better life in forum Authoring (VCD/SVCD)Replies: 3Last Post: 27th Nov 2008, 22:29 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58 -
SUPER doesn't work
By tedgrant in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2007, 15:36
