When I rip the audio from an NTSC DVD and compare it to the same audio from a PAL DVD I find that the NTSC audio track is not only shorter than the PAL but also faster (higher-pitched).
Is there any way to correct this--to have both run at the same rate? Am I just flipping?
Thx.
--B
That usually happens if the resulting .wav file is anything other than the standard 44100hz 16bit.
I am fairly certain you can convert the sample rate in Quicktime Pro WITHOUT changing the speed of the audio. I got into an argument with someone who told me that was not possible, but I have done it, so it is, lol.
I've even done it in the Windows Recorder....but usually I use CDWave.
Need to resample PAL audio to NTSC audio. Is it possible?
By mob in forum AudioReplies: 8Last Post: 28th Jul 2013, 23:51 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
pal audio convert in ntsc audio?
By ashe09 in forum AudioReplies: 4Last Post: 12th Oct 2011, 05:49 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
