Results 1 to 9 of 9
Thread: How long should it take to burn a 4.2GB DVD at 8xspeed
  1. #1
    Member pharries's Avatar
    Nov 2002
    Posts
    152
    I am confused by something really simple.
    With the right driv, firmware and decent appropriate media how long in minutes + seconds should it take to burn a 4.2GB DVD at 8xspeed?
    Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Posts
    5,230
    7-8 minutes.
    Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Posts
    11,301
    I concur !
    Nov 2002
    Posts
    152
    So What is it actually 8x?
    with Cds we knew what time was baseline and so 8x
    with DVDs not so it appears
    Member
    Apr 2003
    Largo, FL
    Posts
    1,244
    Quote Originally Posted by pharries
    For video:
    1X- one hour of video (at a bitrate that will fill the disk- since a disk will also hold any length of video up to 8 hours or more if the bit rate is lowered)- burn time about 1 hour.
    2X- burn time about 1/2 hour (or twice as fast as 1X)
    4X- burn time about 15 minutes (1/2 as long as 2X)
    8X- burn time about 7-8 minutes (1/2 as long as 4X)
    VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Posts
    15,921
    http://www.videohelp.com/dvd#dvdspeeds
    Single Layer(4.7GB) write speeds
    1x (CLV) = about 58 minutes
    2x (CLV) = about 29 minutes
    2.4x (CLV) = about 24 minutes
    4x (CLV) = about 14.5 minutes
    6x (CLV/ZCLV) = about 10-12 minutes
    8x (PCAV/ZCLV) = about 8-10 minutes
    12x (PCAV/ZCLV) = about 6.5-7.5 minutes
    16x (CAV/ZCLV) = about 6-7 minutes
    Dual/Double Layer(8.5GB) write speeds
    1x CLV = about 105 minutes
    2.4x CLV = about 44 minutes
    4x CLV = about 27 minutes
    If in doubt, Google it.
    Member
    Sep 2001
    USA
    Posts
    664
    honestly though, even if your media is rated at 8x speed, id still advise against burning at that speed...i burn all my stuff at 4x, if you go much higher than that it may cause problems with some dvd players.....if your burning on a 16x recorder with 16x media though, 8x should be fine
    How old is your computer ?
    I have an old laptop, PentiumII, it takes 15 minutes with the usb 2.0 port and 2 hrs with the usb 1.1 port.
    Nov 2002
    Posts
    152
    Thanks guys
  1. Replies: 14
    Last Post: 30th Mar 2011, 12:04
  2. How long does it take to Burn a Blu-ray?
    By DGenerateKane in forum Authoring (Blu-ray)
    Last Post: 6th Sep 2009, 05:01
  3. Replies: 5
    Last Post: 2nd Sep 2009, 02:12
  4. Replies: 4
    Last Post: 13th Jun 2009, 01:20
  5. Burning as Divx- burn time-why so long-alternates?
    By Rik62 in forum Newbie / General discussions
    Last Post: 12th Jul 2008, 17:19
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
