Ok I went through like 3 dvdr to out a video on and everytime
i play it it always says disc error playback not avaiable? Any I doing somehting wrong here? The files a Xvid then I encode them with vso dixtodvd version 0.5.2.99 to you know make them dvd ready files then I burn it with nero and nothing man this really sucks I dont wanna waste my disc so can anyone please help me thanks
Tried the Guides section to make sure you've got the process down-pat ?
It could be that your DVD player doesn't like the discs you are using
You might be trying to play PAL on an NTSC-only DVD player or TV
You might not be burning the files correctly
It might be a good idea to get a Rewritable disc until you get the process down. Http://members.dodo.net.au/~jimmalenko/NeroExpress.htm might help with the burning side of things. https://www.videohelp.com/dvdplayers might help you to identify which media has been tested with your player, and also whether your player is Multisystem (PAL & NTSC).If in doubt, Google it. -
When you convert are you making sure to check the option to force NTSC and whatever aspect you want. Xvid files are usually 25fps or something like that. If you convert a 25fps with DivxToDVD, but don't make sure to force it into a 29.97 NTSC conversion it's not going to play. Also, can you burn straight to DVd after converting, or do they need to be authored? I've actually never tried a straight burn after converting with DivxToDVD. I always sned it into TMPGEnc DVD Author and make a simple DVD.
Originally Posted by stantheman1976
Let's clarify a few things here:
25fps would be fine if they were PAL. They'd generally be 23.976fps if NTSC.Originally Posted by stantheman1976
Originally Posted by stantheman1976Not true. It will play if your DVD player can play PAL. PAL -> NTSC conversions and vice-versa are more than likely the cause for most synch problems. One way to avoid such problems is to leave it in the standard it is presented to you in (provided you have the playback equipment).Originally Posted by stantheman1976
Yep, you can even use it to burn if you wish.Originally Posted by stantheman1976If in doubt, Google it. -
I said 25fps "or something like that" since I didn't know exactly. My DVD player wont' read PAL discs, so I always force it to NTSC and haven't had any problems before. I'm not perfect. I was just trying to give an idea of what might be the problem since I know I've had the same problem before.
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
PowerDVD 10 ultra Blu-ray Palyback issue...Video is multicolour snow. HELP!
By BradOZ in forum Software PlayingReplies: 9Last Post: 7th Apr 2011, 18:06 -
What is the fastest MPEG-4 ASP encoder/converter for mp4 phone palyback.
By muuu in forum Newbie / General discussionsReplies: 5Last Post: 12th Jan 2010, 20:53 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
