  1. Audio capturing Help needed.
    I listen to music on my XM sat and DSS Satellite (music channels). I want to capture these audio files for an I-pod. Is this possible? Is this very completed?
    MrBossman
  2. The most basic way is to just take the audio and input it into the line input of your audio card. If you are using Windows then just use the Windows sound recorder.
    If you want something more sofisticated then do an internet search for audio record and you will find dozens of programs to record with or go to http://www.audiotoolsdirect.com/Recorders/ and take your pick. I like http://www.unrelatedinventions.com/Audiotools/
  3. Thanks
    Will these programs save the titles and info on each track?
