  1. i'm basically looking for a FREE program that lets me edit my mpegs and put them into one. i have alot of small mpeg files that i want to edit into one. thanks.
    Apr 2002
    Oskeeweewee Ontario
    Why don't you try the TOOLS section on the left hand side??
    MPEG-VCR seems to be popular for the editing, and TmpgencAuthour seems to be a favourite for authouring..
    Good luck..
    TMPGENC, and use the MPEG TOOLS function in the FILE menu.
    All of your MPEG files MUST be the same specs: resolution, bitrate, framerate, etc.
