I´m having major problems cutting my Avi/DivX files. I´ve tried both VirtualDub and AviChop but neither of the two works. The output files have out of sync. audio. I´m running Win Xp on a AMD Thunderbird 1,4 Ghz.
Any suggestions on other ptrogz? Tips??..please help......
pleaze, if anybody has suggestion about other programs for cutting avi/divx let me know
Oki, really need help with this issue. please write anything that you think might help
use virtual dub
set BOTH audio and video for direct stream copy
hold down the shift key while you are working the slider and it will stay locked in on keyframes and when you cut it wont loose audio sync.
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose. -
... then select "save segment avi".
(I had some problems saving the divx-avi file)
Then the DiVX movie was cut down to fit a 80min cd.
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 12:20 -
What's the quickest/easiest way to cut something from DVD and DivX
By dsajkw in forum EditingReplies: 2Last Post: 2nd Sep 2010, 11:50 -
Cut Divx without Re-encoding
By kman22 in forum EditingReplies: 8Last Post: 26th Nov 2007, 18:39 -
Need a program to combine & cut divx, mpg & wmv
By sync in forum EditingReplies: 3Last Post: 14th Nov 2007, 07:02 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
