I tried searching a bit but evidently didn't know the right search terms.
I've noticed my clips all seem off with one side of the stereo channel (or even mono) louder than the other. Is this my cheap headphones or is it like fm stations that broadcast with one channel's volume lower than the other? The music came from the internet.
Thanks for any insights/links
It could be your soundcard. I have on-board audio, and the left channel does sound louder than the right one.
That's why I'm getting a new X-Fi card. 8) -
this is too obvious.. but have you checked the balance? the all outputs have their own use, the windows play control to check. if its set right.. move it till it sounds right.. not perfect.. but atleast it will sound ok till you get a better card or speakers which ever is the problem.
Well, I'll have to check with my disabled onboard card to see if the volume's off. Yes...I suppose I could do what you recommended which a good idea for a bandaid...I'm now wondering if all the video clips are off...Guess I'll find out.
Thanks -
another thing coulg be your record setting balance could be off causing all your recordings to be off.. just a thought.. id be willing to bet its one of those two..
im refering to the windows play control settings.you might need to unhide all teh devices some may be hidden. -
Well, some came from the internet...which I suppose could have had their recording settings off...Sounds like a huge mess to determin what's going on...I'll have to start with the headphones.
Thx
Remove sound that is at a louder level?
By gutterboy in forum AudioReplies: 11Last Post: 27th Jun 2011, 11:22 -
Sony trv 18 no internal speaker volume, no headphone volume
By websbymark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Oct 2009, 12:39 -
Louder sound via ffmpegX
By maruz in forum ffmpegX general discussionReplies: 2Last Post: 2nd Oct 2009, 05:05 -
Making audio louder in Virtualdub
By BobAchgill in forum Newbie / General discussionsReplies: 1Last Post: 30th Mar 2009, 19:13 -
Multi-Channel sound on 4350 not working 100%, (ONLY 2-channel)
By THX-UltraII in forum AudioReplies: 1Last Post: 20th Feb 2009, 05:35
