I never really gotten into it, but what is this extension for it dosen't affect any work that you've done already is it?
SFK contains the metadata including file marks and peak levels data.Originally Posted by dvdfreak1971
http://www.custcenter.com/cgi-bin/sonypictures.cfg/php/enduser/std_adp.php?p_faqid=567...i=&p_topview=1
http://www.custcenter.com/cgi-bin/sonypictures.cfg/php/enduser/std_adp.php?p_faqid=550...i=&p_topview=1Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
The working file in direct edit mode will be a wav, mp3 or other supported format. SFK holds the data about that file.Originally Posted by dvdfreak1971Recommends: Kiva.org - Loans that change lives.
sfk files are peak data files created by Sound Forge when you load an audio file and will be regenerated if they are deleted when you reload that audio file. If your done working with an audio file you can delete them.
Sound Forge puzzler...
By mjl1297 in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2011, 09:19 -
Using equalizers in Sound Forge 10
By Xdecade in forum AudioReplies: 0Last Post: 6th Jun 2010, 14:12 -
sound forge plays a video (.mov) file too fast
By bobpete in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2009, 13:34 -
Sound Forge Help
By ZOMBE in forum AudioReplies: 2Last Post: 28th Jun 2009, 08:46 -
Goldwave or Sony.Sound.Forge
By lucid_dreams in forum Newbie / General discussionsReplies: 4Last Post: 1st Mar 2008, 01:33
