  1. I ordered some TY01 value discs and when I got them dvdidentifier shows them to be TY03. Nero will only burn them at 1X so I updated my firmware from HWS4 to HWS7 and now Nero wont read any dvds at all. Even DVDRW. I try to write and it says no disc. I can read the disc in Windows but not nero. Then I put the old HWS4 on it and I still have the same problem. Any ideas what I can try?
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Something else besides Nero?
    If Windows sees the drive - don't worry.
    /Mats
  3. If Windows sees the drive - don't worry.
    /Mats[/quote]
    Dont WORRY? I cant burn any dvds now. I used Nero everyday before flashing the drive and now it wont work. I tried EasyDVD and same result. The burning progs wont see a disc in the drive. Im not WORRIED, but I would like to fix it if possible so its more than just a cd burner.
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Tried any other DVD writing apps?
    2 out of 2 aint that bad, but perhaps you should start worrying...
    /Mats
  5. thanks so much for ur help, why bother posting if you dont have anything usefull to say besides maybe i should start worrying.
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    You're welcome!
    At least, I keep your post from falling off the "latest posts" list, am I not? But don't worry, I won't bother you again.
    /Mats
