    Nov 2005
    Can anyone please recommend some PC software that will enable me to edit DVD-RAM discs containing TV recordings? I just want a very basic, simple, idiot-proof package - no bells or whistles - that I can use to edit out advertisements etc. without downloading the recording to the hard drive. The discs have been produced on a Panasonic DMR-ES10EB DVD recorder – I am aware that there is an editing facility on this unit, but I would prefer to do the task on my PC. (I notice the file extension for this video format is ‘.VRO’ – is that unique to Panasonic?)
  2. It's far easier and faster to edit on the recorder. You have to copy to the HD, about 20-25 minutes, if not editing will take forever.
    tmpgenc dvd author, add dvd video and select the DVD_RTAV folder.
    and try use our hidden search feature...try search for
    vro edit
    for more tips.
