I installed the latest 9t version and followed all directions for installing the new binaries. Selecting the mpeg-4 option results in a movie that QT can't use (error -2041). Even selecting the psp profile yields the same result. VLC can play these movies but iTunes won't accept them (if QT won't, of course iTunes won't).
9s worked great (except for no H.264). I installed the 10.4.3 update but used the 9s version after the update and it worked fine. It was only after I installed 9t that things went south.
Any ideas?
Where can I get the 9s version?
Results 1 to 11 of 11
0.0.9t r3 can encode for iPod by using the PSP preset, as confirmed by many users. You can find 0.0.9s at http://homepage.mac.com/major4/ffmpegX_0.0.9s.dmg
Select XviD [.MP4] (ffmpeg) under the Video tab instead of MPEG4 [.MP4] (ffmpeg) after selecting MP4 as a Preset in the Summary tab and it will work fine.
When I use the "MPV Mpeg-4" setting, I get info in the progress timeline and see many lines of "AC EOB marker is absent pos=64". The resulting video may be played in VLC but QT doesn't accept it.
When I revert back to the 0.0.9s version (with its set of codecs), everything (except H.264) works.
Trying the XviD setting (per ahmontgo's suggestion) results in a 4kb file that only takes 1 second to finish encoding.
If someone (major?) would like to see them, I can zip the ffmpegx folders (from Application Support) I'm using for each of the two installations and post them on my website.
I'm running a dual-2.0 G5, 10.4.3, QT7.0.3 "Pro" with mpeg2 codec installed. In my Library>QuickTime folder I have the following codecs:
3ivx D4 4.5.1 for OSX
AC3 Codec.component
AppleIntermediateCodec.component
DivX 6 Decoder.component
FLAC_Decoder.component
OggVorbis.qtx
TSCC.component
I don't see, though, how these can be involved as v0.0.9s (with its set of codecs) works fine.
Again, any suggestions are appreciated.
I should also mention (in case I've not been clear) that the ffmpegx folder inside Application support is named properly and I have been removing and replacing that folder as required for the proper version of ffmpegX.
Re-installed the 0.0.9s app and its required components.
Restarted.
Launched and converted with no apparent problems (DV>mpeg4 for iPod).
De-installed all 0.0.9s components (including .plist)
Installed the 0.0.9t components.
Restarted.
Launched the app & converted the same DV file.
Progress shows normal completion but file has no preview and QT Player will not open it (although VLC will). iTunes rejects it.
"info" window (from the Progress timeline) shows this:
Encoding started on Sun Nov 6 18:19:06 MST 2005
Input #0, dv, from '/Users/blevine/Movies/Clip 01.dv':
Duration: 00:01:17.4, start: 0.000000, bitrate: 28771 kb/s
Stream #0.0: Video: dvvideo, 720x480, 29.97 fps, 25000 kb/s
Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Output #0, mp4, to '/Users/blevine/Movies/Clip 01(9t-618pm).dv.ff.mp4':
Stream #0.0: Video: mpeg4, 640x480, 29.97 fps, q=2-9, 1516 kb/s
Stream #0.1: Audio: aac, 48000 Hz, stereo, 96 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
AC EOB marker is absent pos=66
AC EOB marker is absent pos=69
AC EOB marker is absent pos=68
AC EOB marker is absent pos=91
AC EOB marker is absent pos=65
AC EOB marker is absent pos=73
AC EOB marker is absent pos=98
AC EOB marker is absent pos=67
AC EOB marker is absent pos=70
AC EOB marker is absent pos=72
video:14621kB audio:1812kB global headers:0kB muxing overhead 0.294225%
bench: utime=66.107s
Encoding completed on Sun Nov 6 18:20:13 MST 2005
I believe this same message appears when converting this file using the 0.0.9s app (and its components). However, the resulting file is fine.
Nothing coming from a 0.0.9t conversion works. Most other codec selections result in a 1 second conversion time and a 4kb or 0kb file.
I guess I'll be staying with 0.0.9s although I should point out that Mpeg Streamclip seems to have no issues either before or after the 10.4.3 update. iSquint also seems to work as does MoviesForMyPod (although that app doesn't like .dv files very much).
Well, I don't know..Originally Posted by ahmontgo
I tried my AVI file -> MP4 using the xvid [.mp4] (ffmpeg) setting this time around, and Quicktime still says it's an invalid file (-2041) yet the same file plays fine with VLC.
I'm using 0.9t r4 (according to the About info), even though the text in the scroll box says it's r3.
I guess I'll have to try 0.9s as well and see if that helps.
I simply deleted ffmpegX off the hard drive and installed 0.9s, as well as downloaded and installed the binaries.
Well, suprise suprise.. using the exact same settings as previous (inc. high quality and 2 pass encoding), this time it worked just fine. It's obviously an issue with 0.9t (or the version of ffmpeg it's using).
Very bizarre considering that others don't seem to be reporting this problem. Out of curiosity, what is your system info? (Hardware config, OSX version, QT version, "Pro"?, Apple's mpeg2 component installed?, etc.)Originally Posted by GrBear
Maybe some of this info will help major track the problem and point to the resolution.
I'm running:
G4 sawtooth, upgraded from 500MHz to 1.2GHz
1 Gig of RAM
Mac OS X 10.3.9
Quicktime Pro 7.0.3
3ivx D4 4.5.1 codec
DivX 6 codec
I even removed the codecs in case they were affecting QT's ability to decode the file, but it made no diff.
Yes, very unusual.
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
ffmpeg doesn't work at all
By Paulo2009 in forum ffmpegX general discussionReplies: 27Last Post: 5th Aug 2009, 00:55 -
Tmpgnc doesn't work
By better life in forum Authoring (VCD/SVCD)Replies: 3Last Post: 27th Nov 2008, 22:29 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58
