I did a bit of searching and could not quite understand what I was reading
I have been off this forum for some time got a new hobby other than video I am really out of date as to what is available now.
I am looking to use my LCD 27 monitor tv on my computer as I do not have the space for both a TV and a monitor unless I mount the tv over a fireplace which I heard was really not recomended
What would the best video card for me to get for my PC least expensive
that will give me decent quality reading print on a computer. The LCD MonitrorI bought has a vga input and dvi with resolution of 1000 something I currently have a radeon 9200 SE card in my computer now.
I do not do any gaming or watching video on my Computer so the least expensive way to hook this up is the best. Just incase I really don't like the combination. I also have a wireless keyboard and mouse and rolling chair I can move everything to get the best view for me.
I would post the exact brand and model of your TV monitor. They handle digital video differently. Generally I believe the digital input, DVI, would be best. Someone here may be familiar with that model or it's capabilities and be able to suggest a better video card.
Even with that, you may be disappointed at the results as far as the legibility of text is concerned. TV and computer monitors are designed for different purposes. But with the monitor specifications, someone may be able to tell you how well it will work. -
I got it working very well using the vga input on my LCD monitor , I did not realize the monitor vga plug came off, tried it on the vga on the tv and works better than my old crappy monitor. Clear text and a 9" bigger screen
Good deal
You might see if you can round up a DVI cable and give that a try if your card has DVI output. If VGA works that easy, might be worth a try.
Some few monitors have detachable cables, you were lucky with that.
dellE228WFP 22" LCD monitor to a time warner cable box?
By Ashypoo19 in forum DVB / IPTVReplies: 1Last Post: 8th Apr 2010, 14:24 -
Is Inspiron Zino HD + I-inc iH-252HPB 25" LCD Monitor =HDTV
By surucu in forum DVB / IPTVReplies: 1Last Post: 26th Nov 2009, 08:59 -
Toshiba HD DVD player to Dell LCD 17" monitor
By jascman217 in forum Newbie / General discussionsReplies: 3Last Post: 16th Sep 2009, 21:24 -
Why LCD monitors have still VGA connections?
By Talayero in forum ComputerReplies: 8Last Post: 13th Apr 2008, 02:05 -
19" LCD FP PC monitor?
By majax79 in forum ComputerReplies: 12Last Post: 21st Oct 2007, 01:54
