I have been trying to convert a avi from NTSC to Pal using TMPGEnc Xpress, however when i get about 50% i am given an error, if i load the avi into gspot i am told that the audio codec is not installed could this cause the error?
Also i cant seem to find the audio codec to d/l, gspot says the name of codec is; ac3 (0x2000) "Dolby Laboratories, Inc" and the Audio Media is; WAVE_FORMAT_AC3 (0x2000) and last the audio codec; AC3Filter
So do i only need to d/l AC3 Filter?
Results 1 to 14 of 14
I would use VirtualDub for all kind of avi files, TmpgEnc is good for working with mpg files. For avis with ace sound i use a special ac3 version of Virtualdub. Maybe newer version of virtualdub has full ac3 support, but i used the 1.4.8 version. I don't know if links are allowed here:
http://www.vbc2000.it/public/mkportal/index.php?ind=downloads&op=download_file&ide=26&...ub_148_AC3.zip
If not, then moderator should delete the link, so u can google for "virtualdub ac3 1.4.8" -
thanks n8mare i will try that out,
can anyone help me with the audio codec i cant seem to find 1 that works, i have d/l AC3 filter but that didnt seem to work -
try this:
https://www.videohelp.com/tools?tool=AC3_ACM_Decompressor
that works for my fine -
Thanks again n8mare that did the job only prob is i am still getting the error with a few of the avi's i am trying to convert, when i load them into gspot it says that codecs are install and that there are no errors, same in virtualdub if i select scan for video stream errors it comes up with nothing,
Does anyone have an idea as to what could keep causing the error? -
Im actually using TMPGEnc Xpress, don't know if that makes a difference, i will have to post the error later because i have cleared it now
Well, look. NTSC to PAL conversion is a headache, but can be done, if necessary. If you live at a PAL region, you probably don't need.
Anyway, Tmpgenc is not the proper tool, Xpress or not, but VirtualDub(Mod), as n8mare said.
If you type ntsc to pal in the start page of the web, you will go to:
https://www.videohelp.com/guides.php?howtoselect=4;41#4;41
There are several tutorials. The one that worked fine for me at once is the second one, from users.bigpond. You may want to take a look at it.
Best regards. -
Normaj tried the guide u gave me but no go the sound come out all destorted and quiet like there is a pillow over the mic,
The error i keep ketting is: Invalid sample format (error code 0x80048002) -
Well what I do is I have their AC3 plug-in so AC3 hasn't presented a problem. For MP3 audio and such as long as I have the codec installed,
I use Virtualdub and save the audio as a wave file and then in Xpress I add the video and then add the wave file as the audio, end of problems, sync problems too.
Open V-Dub, open the video. Then under the audio tab, choose Fullk Processing Mode. Then uder File tab choose save wave.
a couple of minutes later good audio ready to go. Really helps with VBR MP3 audio.
Also you might want to scan the video for errors. or extract the Video and the audio separate and then add to Xpress.
Good Luck, I like xpress for ease of use and good quality results. -
Thanks for the input TBoneit but that what i tried from the start and tried without extracting the audio as well
Does anyone else have any suggestions? -
Could anybody tell me why i am getting rubbish sound when following the guide NormaJ gave me, because this actually finished just the sound was pants!
This method has worked well for me:
http://www.johnisme.com/
IMHO it's easier and more reliable to do the framerate conversion as AVI, fix any sync problems, THEN convert to MPEG2. But there's more than one way to skin a cat.
Good luck.
Pull! Bang! Darn!
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 19:10 -
Megui converting error.
By llmercll in forum Video ConversionReplies: 5Last Post: 1st Feb 2009, 18:40 -
Error when converting to avi
By Fashionita in forum ffmpegX general discussionReplies: 4Last Post: 21st Nov 2008, 11:22 -
Converting Error
By RVPizzle in forum Video ConversionReplies: 12Last Post: 28th May 2008, 06:36 -
error converting
By Flying Doctor in forum Video ConversionReplies: 4Last Post: 6th Apr 2008, 05:05
