Recently, when I tried to open my scanner application, I got a message -- something like: "Error opening twain source. Unable to find twain.dll. Copy twain.dll from source disk to Windows."
Using Windows "search" function, I located "twain.dll" on the source disk (cd) and when I tried to copy it to the Windows folder I got a message: Do you want to replace the existing "twain.dll" file (stating the size and modified date of the "existing" twain.dll).
I said no and then, using several different alternative settings, tried to find the existing "twain.dll" file supposedly already in my system, using Windows "search" function. "Search" was unable to find it.
(By the way, "search" was set to locate system files and hidden files, too).
How come, when I try to copy "twain.dll" from source disk to my system, it finds an existing "twain.dll." Yet when I use search to try to find it there is nothing found and when I try to use the scanner software I'm told I need "twain.dll" in the Windows folder?
My USB connected scanner loses the TWAIN driver every time I unplug it. I just reinstall from the disc and it's fine. Never messed with the .dll. For more than you really want to know about TWAIN
http://www.twain.org/
video file and subtitles file are out of sync because of missing intro
By bmaya in forum SubtitleReplies: 3Last Post: 13th May 2010, 11:26 -
Windows XP startup file missing
By SE14man in forum Newbie / General discussionsReplies: 12Last Post: 7th Oct 2008, 10:35 -
Missing or corrupt file in Win2k
By bevills1 in forum ComputerReplies: 8Last Post: 10th May 2008, 20:43 -
Missing a .VOB file?
By Ego Tripper in forum Newbie / General discussionsReplies: 5Last Post: 2nd Feb 2008, 16:02 -
Missing Sensapi.dll File.....Need Some Help!
By RKelly in forum ComputerReplies: 2Last Post: 31st Jul 2007, 16:20
