I'm trying to author with DVD Lab 1.0, and all the disks I'm burning are skipping - intermittantly?
They'll play fine on a little portable Apex that I own, but not on my Kodac DVD player.
If I use Nero (don't laugh) the DVDs I burn play fine on both.
This even happened when I took a trusted source (i.e., a dvd that I own and ripped) and stuck deplexed and replexed (not sure if that's those are the right words) and burned them with DVD lab.
My version of DVD Lab is old, would that be the problem?
Are you using the burning engine in DVD Lab ? If so, that may be your problem. Your version is now quite out of date, but even with the updates, I would never use the built-in engine. Nero is OK for burning DVDs (I wouldn't use it for anything else though).
What media are you using ?Read my blog here.
As far as the burning engine is concerned, I feel a little silly admitting that I've been using DVD Shrink to convert to an ISO, and DVD Decrypter to actually burn.
As far as media is concerned, I've used Imation +R's and Maxel -R's.
Help with burned DVD's skipping
By BDrums1971 in forum Newbie / General discussionsReplies: 20Last Post: 1st Sep 2013, 15:06 -
DVD skipping on certain players...
By Lewshu in forum Newbie / General discussionsReplies: 1Last Post: 5th Jun 2011, 23:35 -
DVD skipping for Client - tried everything we can think of!
By trevmarps in forum Authoring (DVD)Replies: 15Last Post: 2nd Apr 2010, 15:46 -
Skipping a menu on a DVD
By Luriden in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2008, 22:03 -
DVD keeps skipping!
By Variable in forum Newbie / General discussionsReplies: 6Last Post: 21st Jun 2008, 18:05
