    Oct 2005
    Argentina
    Hi im tryin to add permanent subtitles to my avi files with directvob and tmpgenc but the files it creates are bigger and with less quality is there any chance to make them the same size and with the same quality and the subtitles??
    Dec 2004
    Australia
    Not possible. The only way to keep the same quality would be to use a lossless codec. Then the size is going to get much bigger. Best to leave the subs seperate.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes, by using the same bitrate as the original for both a and v.
    No. Reencoding (which must be done to add permanent subs) always reduces quality.
    /Mats
