  1. I am using my ATI All In Wonder to capture from my Video Camera which has a tape in it. My video camera has a composite video out (yellow) and 1 audio out with the red and white cables (just the white one). As a result, the audio only comes through one speaker. Is there a way to change so the audio would come out of both speakers?
    phono splitter (1 male to 2 female) from Radio shack. About $6. Connect it to the camera, then connect the red/white cables to the splitter. *presto*
  3. Member daamon's Avatar
    Melbourne, Oz
    Hi tonemgub,
    Can you be more precise on your "video camera":
    * Does it record as analog or digital?
    * Is the sound recorded as mono or stereo?
    * What make / model?
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    You can also just set your capture settings to mono. You can convert it to stereo* either during editing by copying the track manually,or during encoding or authoring. I'm pretty sure that most software will by default just create a duplicate track when converting a mono track to stereo. I know that's what mine does.
    *won't really be stereo but it never was.
