im very new to this, but ive done alot of reading and i just cant seem to get this to work, i have aruora mpeg to dvd convrter 4.7.1 seems to work ok as far as creating the vob and ifo files, but heres the problem, no audio, what ami doing wrong?
i also have cucusoft avi/mpg to dvd converter and ifoedit but i cant get them to work at all either, anyone give me some help and perhaps a little how to on eiother of these programs??
thanks guys
The original format is probably MP3, for which you have a codec. But with the limited info you've given so far, that's just pure speculation and guesswork on my part.
GSpot is your friend here for telling you what codec(s) you need to decode the source file(s) and also what type of audio your one-click-wonder software has encoded to.
https://www.videohelp.com/play.htm#identify
Make sure you use the latest beta (2.52).If in doubt, Google it. -
ok then what should i be using, i got the audio problem fixed, the converter was putting it somewehres else and i found it and put it with the folder when i opened it with dvd shrink, but it came out really choppy, the audio i mean
i also have another problem, i got a coouple movies on my comp they play fine on here, but i put them on dvd (they are already in dvd format on the comp, just as if i copied them from the disc) the video is rolling. -
Now I don't know what you should be using. I can only say what I am using.
Usualy I am using VirtualDubMod to separate video and audio. At the end I have a video file (avi) without sound and audio file. If the original audio can be used for DVD creation I simply demultiplex it. If not, I decopress it to uncompressed wav file. All this is done by VirtualDubMod. Then I use AC3Machine with BeSweet to convert it to 2 channel ac3 file.
Now as audio is ready for DVD, I try to deal with video. Firstly I am using FitCD to look for the correct resizing value I need to apply for the DVD. Usually I am using 2 blocks overscan. Then I copy the avisynth script which FitCD creates for me and paste it in an avs file with Notepad. I add some filtering to help deblocking, deringing and compessability of the source if neccessary (to decide if it neccessary I open the script with VirtualDubMod activating or desactivating the filtering and looking at the video).
Then I am loading the video (or its duration) in a bitrate calculator to determine the average bitrate required in order to fill the DVD.
Now I am loading avs script in HC. I am setting the bitrate and everything other field I need and click start to encode the material to DVD compliant video.
When ready, I am authoring the video and audio to a DVD with Gui for DVDAuthor.
Finally I create an ISO disk image using ImgTool Classic and burn the ISO to disk with DVDDecrypter. Finita la comedia
audio problem when converting
By Stevex70 in forum Video ConversionReplies: 0Last Post: 25th Mar 2011, 14:56 -
Alienware Aurora ALX - Add HD
By mn072065 in forum ComputerReplies: 17Last Post: 11th Feb 2010, 18:47 -
Converting tv shows audio
By Oem in forum AudioReplies: 3Last Post: 1st Feb 2010, 21:42 -
No Audio after converting
By Seff7845 in forum AudioReplies: 1Last Post: 30th Sep 2009, 04:52 -
Converting audio with glitch
By koberulz in forum Newbie / General discussionsReplies: 28Last Post: 7th Sep 2007, 04:55
