I have benn trying to convert some home videos and other movies to vcd but the quality is terrible,very blocky(technical term) .I have benn using tmpnc to convert but when I burn it the results are terrible.I have a Sony stand alone player 4000 .Sorry if this is a repeat of others but I am stumped. Thanks.
what equipment setup/setting are you using? check out some of the techiques these guys are using in here. practive makes perect...
synchro
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
are you capturing in VCD mode?, try capturing in a high quality mode and then converting using Tmpenc using a good template (TIbrO's aren't bad). this might work.
Capture using a lossless codec (huffy or MJEG), experiment with filters in VirtualDUB and/or TMPGenc, up the bitrate (see what your player will accept) and you will see a DRAMATIC increases in VCD quality.
Macros
p.s. make sure that motion in TMPGenc is set to 'high' at least.
Blocky MKVs
By romanticwarrior in forum Authoring (Blu-ray)Replies: 4Last Post: 2nd Dec 2010, 16:06 -
FFMPEG too blocky
By IMC in forum Video ConversionReplies: 4Last Post: 3rd May 2009, 17:00 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 18:37 -
Blocky or Boxy?
By jethroangel in forum EditingReplies: 2Last Post: 10th Oct 2007, 22:18 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34
