hi, I have a problem with the audio-converting tool TOOLAME.
it won't run, even into ms-dos mode. I try every thing. help me to run it, or prehaps an other programm???
THANX, FRIENDS.
GO ON
make sure you're not using toolame32.exe with TMPG. it only allows you to use the 16-bit version, toolame.exe as an external encoder.
TMPG's audio does work, though the quality is a little scratchy. most encoders do have an audio-only option, and also a lot of MP3 encoders do allow you to do layer-2 encoding
My TV doesn't run either .DTS and .AC3 file from .MKV movie
By galodoido12 in forum AudioReplies: 2Last Post: 3rd Feb 2012, 23:29 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
Will my pc run W7 32bit?
By neworldman in forum ComputerReplies: 6Last Post: 20th Oct 2010, 14:42 -
where is RUN on Windows 7?
By jyeh74 in forum ComputerReplies: 7Last Post: 17th Dec 2009, 18:00 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58
