I've been using studio 9 (V9.3) for over a year for capturing and editing avi without problem.
1. Capture DV via firewire
2. Edit *.avi (delete scenes, transition, title)
3. Save as new *.avi
4. Substract video datecode by DV_DATECODE from the new *.avi
5. Use VIRTUALDUB (subtitle filter) to permanently encode to the video
Somehow on my last project something unusual showed up. The datecode was displayed as [00.01.1900 00:00:00] for all frame numbers whenever I use new *.avi but it look fine on *.avi
_jelir_
found a solution in pinnacle forum.
it works if use WMVideo Advance Encoder but doesn't work if left it to the original codec which is DV Video Encoder. ???????_jelir_
Can my capture card carry 720p?
By MrBlack in forum Capturing and VCRReplies: 4Last Post: 25th Jan 2012, 21:41 -
Will Pinnacle Studio9+ work with Windows 7???
By rrtbusa in forum Capturing and VCRReplies: 0Last Post: 14th Dec 2009, 19:06 -
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
Split xvid/avi at x MB instead of x frames/timecode
By Xavier in forum EditingReplies: 4Last Post: 3rd Mar 2009, 17:51 -
How many CD-R data can an MP3 CD carry?
By coody in forum AudioReplies: 11Last Post: 29th Aug 2007, 16:52
