How do i burn an ISO with Titles/Chapters.
Any programs?
use an dvd authoring tool like tmpgenc dvd author.
make an iso of the the dvd with tmpgenc dvd author or imgtools classic. -
@Lighters, If you use Decrypter and create the Iso image, then as long as it is single layer then when it is time to burn the complete disk would be burned...all menus, extras and chapters...even when you use DL (Dvd 9) as long as you use Dvd 9 blank media. Rebuilder when you set it to Menu and Movie and then have it create Iso imgae to be burned from Decrypter or ImgBurn it will handle doing the image (along with menus). Just wanted to add these options.
MovieDud -
i'm just careful about how much info i post because i got banned from 1 site that wasnt even anything wrong lol.
Anyway, i have the .iso img as i downloaded it.
I want to burn the .iso dvd file and have chapters every 5 minutes like i can do using vso divxtodvd.
So how do i do this, i found out i could make the DVD by using DVD Decryptor -
To borrow mats' terminology:
An ISO image is just a bucket. You need to extract whatever is in that bucket before you can modify it.
Once you have extracted (presumably) a VIDEO_TS folder, I'd test playback using something like PowerDVD to see if there are any chapters in the file already. Then you should be able to add custom chapters in an authoring program such as TMPGEnc DVD Author if you need to. Then you can burn the VIDEO_TS folder it outputs as per normal.If in doubt, Google it.
Multiple Titles In A DVD ISO To A Single AVI
By Simmons in forum Video ConversionReplies: 1Last Post: 9th Aug 2010, 01:32 -
Cannot preview titles and chapters
By YonB in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Mar 2010, 15:23 -
How to convert Titles to Chapters
By Psymon007 in forum Newbie / General discussionsReplies: 14Last Post: 11th Jun 2009, 18:20 -
Multiple clips as chapters instead of titles
By mhar4 in forum MacReplies: 4Last Post: 9th Jun 2008, 09:40 -
How to merge several chapters or titles together
By guns1inger in forum DVD RippingReplies: 0Last Post: 26th Dec 2007, 22:25
