    Oct 2005
    Argentina
    Hey pals im really a newbie on this, i am from argentina. I have some video (avi) files that i converted with diko. But now i have 10 gigas of files avs, mpa and i need to know how to pass them to a 4 gb iso file or vob files
    I hope u can help me
    diko outputs a complete dvd...you must have done something wrong. check the log files if any.
    or use something else like divxtodvd,thefilmmachine,avi2dvd.
    Oct 2005
    Argentina
    I read on a tutorial that when those files are created then you have to convert them to vob i think with the dvd lab but the tutorial of that was in a link that it was broken. Diko only generated 10 gigas of mpv mpa files, does diko create directly vob or iso files of 4 gigas ready for burning them on the dvd?
  4. Ok, you're missing a step... Goto the configuration menu, the Authoring tab, and check the "Author Disc" check box, then the "Create DVD Image" and "Burn with DVD Decrypter" boxes.
    Oct 2005
    Argentina
    I checked those boxes. Not the one of dvd decrypter cause i wanted to copy with nero but with author disck and create dvd image checked the files where the ones of 10 gigas and mpv mpa, avs etc.
    How do files are created to u just an iso image ?
  6. If you configured DIKO to author then it created the video title set. Look for a directory called Video_TS. It contains all the files needed to make a dvd. The vob files are in Video_TS. You can use that to burn a dvd.
    If you want an ISO you can use Imgtool Classic to convert the Video_TS to an ISO.
    If you are making a DVD then you can use DVD Decryter as previously mentioned. It works as well or better then Nero for burning.
    You can also use those mpv and mpa files to author a DVD using authoring software if you don't want to use DIKO for the authoring.
    Oct 2005
    Argentina
    I used diko and it never created me a folder name video_TS just this kind of files on the folder i specified the convertion
    I have these options on authoring
    I want diko to create a video_TS folder with vob files or a iso image i got diko free 2.12
    can this version create vob files or iso or just the ones from the image???
  8. If diko has not created a video_ts or an iso it usually means it has encountered a problem somewhere along the process
    Have a look at your log file to see if any errors
    visit the diko forum http://www.vmesquita.com/forum/ because there are lots of threads concerning this
    do a bit of reading
