I have a song and its MP3 format yet once i select it and put it in my library it doesnt work, the first 5 seconds work then it stops and goes to next track. It works using windows media player though????
So whats the deal?
maybe it's VBR not constant 128 or whatever bitrate
usually players don't like variable bitrates, encode it as constant, and should be fine. -
OR, maybe it's mp3PRO.....or the bitrate is too high or low, not under your player specifications.
I use musicmatch, file conversion under File option in menu.
You should use the software that came with the player, that should do it too. I know that Creative's soft does that.
if not, download musicmatch, it's free.
Full Screen Ipod Nano 5th gen conversion
By nerys in forum Video ConversionReplies: 12Last Post: 16th Jan 2010, 14:31 -
[solved] ffmpeg and iPod Nano V1.0.2
By Pixelartist in forum LinuxReplies: 6Last Post: 26th Nov 2007, 09:56 -
iPod Nano Movies
By rbaroncpd in forum MacReplies: 1Last Post: 15th Nov 2007, 09:18 -
IPod nano with video and IPod touch
By SingSing in forum Latest Video NewsReplies: 0Last Post: 6th Sep 2007, 11:11
