I'm trying to add subtitles on an AVI movie with multiple audio tracks...
On ffmpegX I select passtrouth both on video and audio tabs (I dont' wanna re-encode the divx!) and then on Filter Tabs I select the SRT file.
Everything seems to work fine. FffmpegX goes to the end. But when I check my movie I see that I have only one audio track!
FfmpegX correctly joins the subtitles to the AVI but delete all the audio tracks except the first...
Is there a solution to mantain all my audio tracks?
Thanks in advance.
I don't thing you can do it without re-encoding the video. I think it has to be able to "burn" the subtitles into the video for it to work.
anyway, the only encoder that works with the subs for me is mencoder setting. And even with that it doesnt change the font size that I select. Good luck.
Adding Subtitles to MP4 Files
By elapid in forum SubtitleReplies: 13Last Post: 26th Nov 2015, 20:58 -
Adding SSA subtitles to MP4 files
By ngngokkiu in forum SubtitleReplies: 19Last Post: 21st Feb 2012, 06:24 -
Adding working subtitles to .mkv files
By Yoven in forum Video ConversionReplies: 1Last Post: 10th Oct 2010, 13:43 -
adding subtitles to dvd files
By byrnfran in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2007, 09:40 -
Adding subtitles to an AVI
By ker-plop in forum MacReplies: 12Last Post: 8th Oct 2007, 09:48
