hey everyone, im trying to work a spreadsheet, but im not too familiar with Excel, so i dont really know how to change certain settings. anyways, my problem is that i need to enter numbers in a spreadsheet, numbers such as 0123 where the 0 is crucial. however, when i enter 0123 and click another box, the 0123 cuts off the 0 and ends up 123, which i DONT want. my friend suggested that i put a space inbetween like this: 0 123, but that looks awkward, plus its not how i want it. so if anyone can please advice on how to enter 0123 so that it will stay as 0123, i would really appreciate it. bless u all.
- skip
Results 1 to 10 of 10
Wow! You got shocks, pegs... LUCKY!
There is only one way to do it, but it will no longer be a number. Right click on the cell, select cell properties, and make it text instead of a number. You can also change the alignment if you wish.
Btw, you CAN sort on the value, just not do any numerical calculcations.TANSTAAFL -
Highlight the required cells, go to Format tab, Cells, then under Number tab, select text under the category, and click OK. Now the 0 should be displayed before the numbers as 0123.
EDIT: Looks like greenlantern and Prot got there before me. There were no posts as I replied.
thanks guys i tried that but the box has a green tab at the top left corner of it. and the 0123 is towards the left side and all my other numbers are alligned to the right: like so
. how can i get that all fixed up? thanks
Wow! You got shocks, pegs... LUCKY! -
okey thanks, i figured out the green thing. its like when mic. word underlines grammatical mistakes, u can chose to ignore, them, so its no biggie, thanks again
Right Click desired cells > Format Cells > "Custom" Under "Type"
put in four zeroes. The next time you put numbers (depending on how many) into those cells 0 will precede the number you put in (in this case up to 4 digits).
IE type 12 and you should come out with 0012 automatically
type 343 and you should see 0343 -
Yup, this is the way to go.Originally Posted by deadpac
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
problem with copying in Microsoft Excel
By mazinz in forum ComputerReplies: 1Last Post: 30th Mar 2010, 20:45 -
.mvb files... Giving me trouble... Errr
By Ronaldr in forum Software PlayingReplies: 4Last Post: 5th May 2009, 00:56 -
How to activate macro's in Excel 2007 with a spreadsheet from Excel 97
By blinky88 in forum ComputerReplies: 3Last Post: 11th Feb 2009, 12:21 -
DVD Player is giving me trouble wth DVD-Rs
By Veepa in forum DVD & Blu-ray PlayersReplies: 4Last Post: 27th Nov 2007, 11:31 -
Microsoft: Free and open source software violates 235 Microsoft patents
By rkr1958 in forum ComputerReplies: 32Last Post: 12th Jun 2007, 00:36
