index out of range (240) WTF is this????
After 15 hours of encoding and only remaining one hour it gives me that error, this sucks
another thing is there any way that i can encode half of and mpeg and later encode the other half and join them afterwords?
Suet up your mpeg and go to the advanced tab and setup a source range (double click on the filter move the slyder halfway) click ok then file then save project. then reset up the source range (move to end button hit your right arrow and click the set a beginning or what ever it is and then move your slider all the way to the end and set it as the end) then change the output file name and save it. run either one when you want and after they are both done, go file, mpeg tools, then merge cut. add the first one then the second one and set your outputfile and click run.
Weird Error message
By SIRCOOKS in forum ComputerReplies: 5Last Post: 27th Sep 2011, 10:30 -
Weird Error - VGA to RCA
By HamishT in forum DVD & Blu-ray RecordersReplies: 5Last Post: 7th Mar 2009, 20:18 -
Weird MKV Error
By M1rth in forum Video ConversionReplies: 6Last Post: 14th Feb 2009, 16:29 -
Weird error: (-10008)...
By visitor13 in forum ffmpegX general discussionReplies: 1Last Post: 11th Jan 2008, 03:25 -
VirtualDub with really weird error
By dimtim in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2007, 18:08
