I joined 2 .avi's, then converted them with "DVD ffmpeg".
When I went to burn the resulting VIDEO_TS folder in Toast, I got the message that the disk I was using was encrypted with CSS, and Toast couldn't burn it.
What's up with that? I thought CSS was something you only found on DVD's, not inside a .avi file.
Results 1 to 9 of 9
I don't think it is encrypted. Probably something misleads Toast. You may convert the VIDEO_TS into a DMG image file with the "img" tool (you must select the folder containing both VIDEO_TS and an empty AUDIO_TS), then burn it with Disk Utility.
Yes... interestingly this seems to be a quirk, where sometimes I get an export that toast can read, and sometimes I get one that can't, so I've just been quitting ffmpegx, restarting and re-encoding and eventually I get one that can be read by toast and I'm good to go.
Quality is still and issue, because any limitations in the source material or the burn really do show up on the 42" plasma
AACS Bluray encryption
By BIFFtheSTIFF in forum MacReplies: 0Last Post: 17th Jun 2011, 22:26 -
Does GI Joe: Rise of the Cobra use a new encryption...
By rayden54 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Apr 2010, 11:45 -
Is WPA encryption really better than WEP?
By yoda313 in forum ComputerReplies: 34Last Post: 25th Oct 2009, 23:14 -
Best encryption algorithm?
By alegator in forum ComputerReplies: 5Last Post: 11th May 2009, 00:37 -
BD+ encryption blue-ray
By herbapou in forum Blu-ray RippingReplies: 4Last Post: 24th Mar 2009, 08:58
