Can someone who knows please tell me what the DC component precision setting in TMPGEnc means and what it does? Options are 8, 9 or 10 bit but I can find nowhere any recommendations as to which setting will yield the best quality results. Nor can I find anywhere an explantion of what it does so I can make up my own mind.
90% of my encodings are of downloaded AVI files and all I want to know is which of 8, 9 or 10 bit is the best setting to get the highest possible quality.
Here's maybe the clearest explanation:
(From http://www.dvdhelp.us/index.html?html/tuttmpgencadvvideo.html~mainFrame)DC component precision
The DC component represents the average brightness of a block (8x8 pixel region). In MPEG-1 video, this is permanently set to 8 bits, but MPEG-2 allows higher precision. It is important that the DC component is accurately represented, so a setting of 10 is recommended for MPEG-2 sequences, unless you are encoding using a low bitrate.
Or this explanation, a little more complex:
(Sorry, lost the source for this.)DC component precision
10 bits
This controls the precision of the discrete cosine values used in the image compression (this translates the image into a series of interfering frequencies and lets the program eliminate frequencies that aren't visually relevant - this is similar to the compression used in JPEG images). Higher values results in better quality, at the expense of encoding time.
Seems 10bit is almost always best.
That's from http://dvd-hq.info/Compression.htmlOriginally Posted by redwudzIf in doubt, Google it.
Although a bit "old" that guide is still an essential guide for those that wish to learn the in's and out's of TMPGEnc Plus.Originally Posted by jimmalenko
Higher DC precision is only better assuming an unlimited bitrate. The setting essentially sets how much of the high and low frequencies are discarded. Higher DC precision discards less. It is keeping more data, but that data must be represented and that takes up bits. Unless you are using a high bitrate, using a DC of 10 will absolutely kill your quality.
My general rule for DVD encoding is 4mbits or less use DC of 8. Anything up to 8mbits use a DC of 9. I rarely use 10.
Here's what the CCE manual has to say about it:
In general the optimum settings cannot be determined since changes depend on the details of the picture and movement intensity. For pictures with intensive movement and fine bumps, a low number of bits is appropriate. For smooth pictures with little movment, a higher number of bits is appropriate. A low number of bits may be specified for use at a low bitrate up to 4 Mbps, and a high number of bits may be specified for use at a high bitrate. -
Thanks for that. I was actually wondering what is considered a "high" bitrate. FWIW I am usually producing SVCD (even on DVD), so I am mostly in the ~2500kbps range. In this case I guess my use of 10 bit DC precision is overkill. I shall revert to 8 bit and see if I notice any difference.
TMPGEnc Xpress - Clip Settings - No setting for 8:9 PAR
By terpsfan101 in forum Video ConversionReplies: 13Last Post: 17th Jun 2012, 05:28 -
TMPGEnc 4.0 XPress XVID Compression Confusion & Archival Suggested Setting
By timmer545 in forum Video ConversionReplies: 4Last Post: 26th Mar 2011, 11:54 -
TMPGEnc 4 Divx Setting
By Anakin in forum Video ConversionReplies: 2Last Post: 14th Oct 2009, 17:21 -
View intra DC precision
By Bergen in forum Video ConversionReplies: 1Last Post: 14th Aug 2009, 09:20 -
TMPGEnc DVD Author 3 - Quick Question on a Setting
By heyjjjaded in forum Authoring (DVD)Replies: 4Last Post: 5th May 2008, 17:04
