Page 2 of 2
FirstFirst 1 2
Results 31 to 36 of 36
  1. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Originally Posted by slacker
    BTW FulciLives,
    -27db (Vegas default) with compression disabled came close but still too SOFT. Tomorrow morning I will try -31db and see what happens per your recommendation.
    Let us know what you find then and good luck
    - John "FulciLives" Coleman
    P.S.
    Burn a couple of sample videos unto a DVD disc and play back on your regular stand alone DVD player. Have one sample be the LPCM audio while the other sample uses the AC-3 audio.
    Various filters on a computer (like the AC3 Filter) and their settings can make AC-3 behave (sound) abnormal. If you use different "tracks" on the DVD you should be able to get both samples on one DVD-R or DVD-RW etc.
  2. Member slacker's Avatar
    Jan 2004
    SF, CA, USA
    Thanks FulciLives!
    Will take your advice!
    Let you know!
  3. Member slacker's Avatar
    Jan 2004
    SF, CA, USA
    By jove FulciLives...
    I think you did it! -31db dialog normalization, uncompressed (line mode none) @448kbps, 256kbps, and 192kbps sounds EXTREMELY, EXTREMELY close.
    Maybe Sound Forge could get me 1 hair closer... (SCREW IT!). I'm satisfied.
    One more road block overcome!
    Thanks all!
  4. Member FulciLives's Avatar
    May 2003
    Thanks all!
    I had suggested 448kbps 2.0 AC-3 because you really seemed to want something as close to LPCM as possible ... and there is nothing wrong with 448kbps 2.0 AC-3 but the bitrate that seems to make the "most sense" for 2.0 AC-3 is 256kbps ... unless you have really amazing hearing (and high end audio gear to go with your wonderful ears).
  5. Member slacker's Avatar
    Jan 2004
    SF, CA, USA
    FulciLives,
    I'm a purist at heart and default always to archive quality if I can. But I'm with you. My ears are good but they're not THAT good. My Panny dvd recorder outputs 256 kbps AC-3 and it sounds fine. I think 224 kbps would be fine as well if there WERE size contraints.
  6. Most direcotr comments streams are 192 Kbps
