Is there a good easy to use one step convert from divx to mpg/mpeg or avi?? The "guides" section did not have any.
Fred
Panasonic DVD Recorder E50. (Standalone).
Dlink DSM320 Media Lounge.
Mitsubishi 50" 4:3 TV.
Home built AMD XP2000 system with LG DVD Burner (WIN98SE).
eMachines T3882 with Liteon DVD burner (WINXP). -
Difficult to imagine what you mean as divx are generally avi. If you mean a file with extension .divx well I am not sure, but I think I have read that this is a hack of the avi, so simply rename it. What I can suggest is avidemux2. Hmm, this is one step, but for easy to use, well, I don't know (for me it is easy
Yep, .divx is based/hacked on avi. Simply remux to avi using VirtualDubMod, AVIMuxGUI, etc. to be left with a stock standard avi without chapters, menus, etc. Renaming should also work, since any parser that can parse avi's should also be able to parse divx files, just without the chapters and other unsupported features.
Thought it was Xvid? Or is that a Hack of Divx? WE can have many containers,doent mean they are hacks?
The "guides" section did not have anyRead my blog here.
Originally Posted by guns1inger
I'm guessing the OP didn't realise that DivX were AVI, or a hack thereof.
I *think* he meant that when you put in "DivX to AVI" or "DivX to MPG" you get no results returnedIf in doubt, Google it.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Reading AVI/MPG/DIVX files from a BD-R in PS3 or other
By harryman in forum Authoring (Blu-ray)Replies: 1Last Post: 4th Dec 2011, 09:40 -
Burning MPG and DIVX to a DVD
By OldGuyWhoBurns in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2010, 21:12 -
DOS multiplexing for DivX and/or other MPG?
By Figge in forum Video ConversionReplies: 2Last Post: 25th Mar 2009, 02:55 -
mpg/divx --> 3gp anyone?
By trancer_84 in forum Video ConversionReplies: 7Last Post: 6th Nov 2007, 10:32
