I want to burn a clip to a cd so that a person can play it from their DVD player or their computer (as a quicktime). So i want to burn what i guess you would call a hybrid VCD/data CD. I don't mind that the media is dupicated, cuz the clip is small.
Is this possible? I tried using toast to burn a CD, and i was able to do this in 2 seperate sessions, but it didn't work so well. The playback in the quicktime was atrocious. I can't seem to find a way to burn everything simlultaneously. Can this be done? If there is a solution for the mac platform that is preferable as i don't have a PC.
thanks
scott
What about making a simple VCD? You can fit 80' movie per CD, and MAC applications to encode + to author any clip should be easily available...
Yes, it's quite possible. VCDEasy allows you to add data files to the ISO file system part of a VCD.
/Mats
Hybrid Car ??
By jdawson1960 in forum Off topicReplies: 19Last Post: 21st Nov 2008, 22:02 -
VCD o SVCD with extra data (installers)
By pmaril in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th May 2008, 17:17 -
VCD / Audio / Data in only ONE CD!
By demonlhama in forum Authoring (VCD/SVCD)Replies: 9Last Post: 15th May 2008, 09:53 -
Trying to make AVCD/VCD with audio data
By Vejita-sama in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Aug 2007, 15:15 -
Vcd + data simple project
By wilsoncortez in forum Authoring (VCD/SVCD)Replies: 13Last Post: 29th Jun 2007, 23:06
