Hi guys I need some help in finding a PC based solution for coverting quicktime files i.e. .mov to mpeg and aiff to in wav. The mpeg files need to be dvd compliant so I can take them in DVD authoring software. Previously I used Sonic DVD transcoder but we are trying to faze out the mac's and find a pc solution. Info about Sonic dvd transcoder is found below so you know what I had before,
http://www.wave-report.com/archives/1999/90860401.htm
any info would be helpful
most windows mpeg encoders prefer the avi container instead of mov container.
you could use quicktime pro and export to dv avi,huffyuv avi,uncompressed avi and then use any encoder.
or change to avi container on your mac, see https://www.videohelp.com/forum/viewtopic.php?t=277983 -
its a pretty time sensative job and we need minimum time spent transferring files from mov to avi to mpeg. I suppose if they come in .mov then using the batch process of sonic dvd transcoder is the quickest way
Install QuicktimePro, then install either Sorenson Squeeze or Canopus Procoder.
Both can do batch, both can accept QT files (with the various available or installable QT codecs) and both can output MPEG.
capturing dvd compliant mpeg-2 with vdub
By wolfdogg in forum Capturing and VCRReplies: 0Last Post: 10th Jan 2012, 20:06 -
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 16:10 -
need to join 2 dvd compliant mpeg files (having identival characteristics)
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 11:37 -
Video corruption when trying to convert MPEG-2 to DVD-compliant
By DB83 in forum Video ConversionReplies: 2Last Post: 31st Jan 2008, 20:00 -
No audio in dvd compliant mpeg 2 files
By Bertieboo in forum Video ConversionReplies: 6Last Post: 14th Nov 2007, 16:35
