I am just about to burn my first DVD that i have authored in DVDlab Pro. I have a few rograms on my computer at the mo: CopytoDVD, Nero 6, DVD Dycrypter, DVDlab Pro 1.53.
I was wondering which you would say is the best. I was also wondering about burning it as a ISO this was from a previous question
Why is creating an ISO better and how do I create one?Once it starts playing it is either in sync or it is not. You don't play video at one speed and audio at another. If you author a disk and it plays in sync on your hard drive, it will play in sync once burned, assuming the burning app does not screw with the structure. Another good reason to create an ISO and burn with DVD Decrypter/Imgburn.
Regards Jim
Some burning apps (such as nero) tinker with the file structure you actually burn. This should make easier for you by automatically creating folders called VIDEO_TS and AUDIO_TS. In theory this shouldn't pose a problem, but from comments such as that you quoted thats not always the case. This doesn't happen when you create an ISO, you burn just what you want exactly how you want to.
You'll probably find the 99% of the time you don't have any problems but that 1% can really piss you off. And so many people routinely create and burn ISOs. I personally use them for the convenience of having a single file per DVD, and I prefer to burn with DVD Decrypter which as you said will only burn ISO.
So to answer your last question, how do you create them. You will probably find this is an output option (I'm not familiar with DVDlab) or you can create one using ImgTools Classic (make sure you use the free Classic version).
- e404pnf
Creating a DVD with menu with several ISO files
By SandraKlim in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2011, 13:00 -
Creating MDS file automatically When ripping to ISO With ImgBurn
By bbanderic in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2010, 21:53 -
Creating ISO from VOB's
By chronic777 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2009, 13:36 -
Problems Creating ISO with DVD Fab Decrypter
By ViRaL1 in forum DVD RippingReplies: 1Last Post: 25th Jan 2009, 12:30 -
HELP! FAVC 1.04- Why is it creating 0 byte iso's at times?
By spexwood in forum Video ConversionReplies: 7Last Post: 5th Dec 2007, 23:40
